on1ski
Jan 25, 2020Aspirant
ReadyNAS Pro 6 won't boot after failed drive addition
I've had a ReadyNAS Pro 6 (v2) for about 5 years without issue. I can't recall the OS version, but it is the latest from Netgear. Five bays hold 3TB disks configured for RAID 5 (disks are Seagate ST3...
- Jan 28, 2020
Everything is back to normal and working fine. Many thanks to Sandshark and StephenB ! The problem was the power supply. Once I hooked up an old ATX supply harvested from an old computer, the system was able to complete the restriping and resyncing need to add the sixth disk. I now have plenty of head room and can begin a migration to a new system.
I'm finding some references to those who use rsync between a FreeNAS server and a ReadyNAS server. I might do that instead of buying a large external USB drive, and then use my existing ReadyNAS as my backup to the new server once I build it. Any comments on that would be appreciated.
Thanks again!
Sandshark
Jan 25, 2020Sensei
You probably had another drive fail during the re-sync.
But let's eliminate a NAS chassis problem first: Boot the system without any drives (labeling them so they go back in in the same order later). If it boots with "no drives" displayed, the chassis is probably OK.
If you have the ability to test each drive on a PC with vendor tools and a USB dock for the drive, this is the best next step. If you don't, the disk test from the boot menu can give some information.
Once we find out the status of the hardware, we can move on to potential ways to recover your data. Note that you are likely going to need a means of storing all that data while you reset the NAS. But that gets you started with the backup plan you are best served to have in place before a failure.
on1ski
Thanks for your reply and willingness to help.
I removed all the drives, and the system does not boot past "ReadyNAS". I also discovered that I cannot enter the boot menu, with either disks or no disks installed.
So I have a chassis problem?
- StephenBJan 25, 2020Guru - Experienced User
Sounds like it. Can RAIDar see the NAS w/o disks? https://kb.netgear.com/20684/ReadyNAS-Downloads- on1skiJan 25, 2020Aspirant
RAIDar does not see the unit. Sorry, I should have pointed that out before.
I have lots of fan noise, but otherwise, nothing except "ReadyNAS" on the device display...
Thanks again for your help.
What to do??
What to do??
It could be the power supply - and with some effort that can be replaced.
If you don't have a current backup:
If you purchase a new OS-6 x86 ReadyNAS (RN300 or better), you can temporarily mount the Pro-6 disks in the replacement NAS so you can copy off the data. https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86 If the RAID array isn't fully in sync (likely given the failure), you likely would need a data recovery contract from Netgear. https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
If you can connect the disks to a PC (likely in an USB enclosure), you might also be able to extract the data yourself using R-Studio RAID recovery software ( https://www.r-studio.com/ )
