tb303
Jan 14, 2016Guide
Readynas Pro 6 won't boot
Hi, Since years I am a happy ReadyNas Pro 6 owner. Half a year ago I upgraded the ReadyNas Pro 6 to Readynas OS6. It worked just fine and fast! A month ago I stared to have some disk problem...
- Jan 20, 2016
Thanks to the great help of mdgm my Readynas Pro 6 is running the lastest Readynas OS6 again!
I ended up using dd on a debian life boot disk to dd flash the image mdgm supplied to me back to the internal flash.
After that I mounted the partition and copied the supplied serial number file to the internal flash.
Mdgm, thanks for you great support!
Kind regards,
Michel
tb303
Jan 14, 2016Guide
A few screenshots of the bios:
