platteau
Aug 24, 2020Aspirant
ReadyNas Pro Business Edition - Raidar 6.5 can't find Netgear storage
I just upgraded my mac os to Catalina. I have been using Raidar 4.38 to access my ReadyNas Pro Business Edition. This version is not compatible with Catalina so I downloaded and installed Raidar 6.5 ...
Aug 24, 2020Guru - Experienced User
RAIDar 6.5.0 should be working fine with Catalina. You should check your internet security settings, as it does use broadcast packets that your system might be blocking.
Though RAIDar really isn't needed very often.
