David_H
May 31, 2017Tutor
ReadyNAS Pro Business Edition Disk Overheating
Hi, I have a 6 disk ReadyNas Pro Busdiness Edition [X-RAID2] (not sure of the exact model number) with firmware RAIDiator 4.2.28. Last night I recieved a notification that disk 5 had exceed...
- May 31, 2017
Well if you power down, remove the disk and hook it up to a PC you should be able to see if the PC's reporting any issues with the disk.
If you power down, remove your disks (label order) and put a scratch disk (must not be from your array) in that slot do you get reports of temperature issues with just that disk installed?
Welcome to the Community!
mdgm-ntgr
May 31, 2017NETGEAR Employee Retired
