David_H's avatar
David_H
Tutor
May 31, 2017
ReadyNAS Pro Business Edition Disk Overheating
Hi,    I have a 6 disk ReadyNas Pro Busdiness Edition [X-RAID2] (not sure of the exact model number) with firmware RAIDiator 4.2.28.    Last night I recieved a notification that disk 5 had exceed...
  • mdgm-ntgr's avatar
    May 31, 2017
    Well if you power down, remove the disk and hook it up to a PC you should be able to see if the PC's reporting any issues with the disk.
    If you power down, remove your disks (label order) and put a scratch disk (must not be from your array) in that slot do you get reports of temperature issues with just that disk installed?
    Welcome to the Community!
ProSupport for Business
