dman66
Jun 27, 2012Tutor
ReadyNAS Pro Data Recovery? (#18789299)
I was attempting to upgrade the firmware in my ReadyNAS Pro from 4.2.13 to 4.2.21 and it bricked itself (see the case referenced). Is there any way to recover the data outside of the ReadyNAS? I...
mdgm-ntgr
Jun 27, 2012NETGEAR Employee Retired
Well if Amazon would let you return it you could buy an Ultra 6 Plus (3 year warranty) or Pro 6 (5 year warranty) and try the suggestion I gave above.
As for recovering the data using a Linux machine (if you really want to do that) you'd need to start the RAID, scan for the volume and mount it.
I think the commands you'd need are something like this:
Edit: oops meant to say Amazon.
sudo su
apt-get install lvm2
mdadm --assemble --scan
vgscan
vgchange -ay c
mount /dev/c/c /mnt
