Harold825
Apr 14, 2020Aspirant
Readynas PRO OS6 loses network connection
Hi , I have a Readynas PRO6 with OS6 (6.10.3) installed. every once in a while the Readynas loses network connection (Raidar , Putty , windows explorer). Sometimes it happens after 30+ days , so...
Harold825
Hi, thanks for the quick reaction !
It has 2GB (2x1) Memory and I upgraded the CPU as well (Core2DUO) but not sure which, long time ago...
reg,
Harold
Apr 14, 2020Guru - Experienced User
That should be enough.
Free_extent_buffer is part of btrfs, so the most recent one is rather concerning.
You should certainly make sure you have an up to date backup. Have you downloaded and looked through the full log zip file?
Also, generally you should run multiple passes of the memory test. Did you do that, or only run one pass?
