Dane2000's avatar
Dane2000
ReadyNAS Pro Pioneer Edition and disk 4Tb
Hello all! I need your help. I've use ReadyNAS Pro Pioneer Edition with 4 disks and with no RAID (stand alone volumes): 500Gb, 2*2Tb, 4Tb. So, I want to add another 4Tb disk. But no luck. NAS has se...
  • StephenB's avatar
    Sep 04, 2019
    Dane2000 wrote:
    Problem has no solution if I'll use 4.2.x systems?
    I think not.  Though one practical possibility is for you to back up your 500GB volume, and remove it.  Then you should be able to add a new bigger volume (re-creating the shares on the original volume and restoring the files from your backup).
    Dane2000 wrote:
    In additional: in this case, I'll must to search, how to backup all my huge data?
    You should have your data backed up anyway.  RAID isn't enough to keep your data safe - and you don't even have RAID redundancy.
    USB backup drives are a cost effective way (though I prefer backing up to other NAS myself).  You can connect them to the Pro directly, though you will find it's faster to back up over gigabit ethernet (connecting the USB drive to a PC).  There are several windows utilities that can handle this automatically (on schedule) - including FreeFileSync.
    If you prefer to connect the drive to the NAS, you can set up incremental backups using rsync from the NAS backup job menus.  The trick here is to pretend the source is remote (using 127.0.0.1 for it's IP address).
    Dane2000 wrote:
    Shall I changed system to OS6? Will it solve my problem?
    The OS-6 software manual says it will (see page 24).  http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
    Though I haven't tried it (I use XRAID on my 6-bay NAS).
    FWIW, if you do convert to OS-6 I suggest upgrading the memory in the Pioneer.  Newer ReadyNAS have at least 2 GB of RAM, the Pioneer shipped with only 1 GB.
ProSupport for Business
