rklunder
Oct 18, 2014Aspirant
ReadyNas Pro Pioneer Resyncing issue
Hostname: NAS
Model: ReadyNAS Pro Pioneer Edition [X-RAID2]
Serial: 001f33ea2aeb
Firmware: RAIDiator 4.2.27
Memory: 2048 MB [4-5-5-15 DDR2]
IPv4 address: 1: 192.168.1.9
IPv4 address: 2: Not Connected
Volume C: Online, X-RAID2, 6 disks, 18% of 7394 GB used
Problem events in a nutshell:
-System crashed replaced all drives, year later system was resyncing
-Reinstalled OS to attempt fix, after a while, system started resyncing drives again
-Factory reset, one drive finally listed as dead.
-Removed dead drive and tested disk in windows and with WD test software, It worked FINE!!!!!!!!
-Did factory reset, system did a re-sync which took a long time, during which it rebooted a lot, but it seemed ok after that finished (but i didnt test for long).
-Added new sixth drive, system re-stripped, and now it is re-syncing
-The health of all drives appear fine
The problem is it is taking forever to re-sync and the system is rebooting frequently. Is rebooting over and over normal for re-syncing (see log below)? Given the fact that it does not state Rebooting device each time, is my system crashing?
Cut and paste of front view log showing the constant rebooting:
Severity Date Message
Sat Oct 18 21:18:59 EDT 2014 System is up.
Sat Oct 18 21:03:42 EDT 2014 System is up.
Sat Oct 18 20:51:10 EDT 2014 System is up.
Sat Oct 18 18:29:53 EDT 2014 System is up.
Sat Oct 18 18:10:18 EDT 2014 System is up.
Sat Oct 18 17:00:07 EDT 2014 System is up.
Sat Oct 18 16:48:03 EDT 2014 System is up.
Sat Oct 18 16:26:30 EDT 2014 System is up.
Sat Oct 18 16:07:39 EDT 2014 System is up.
Sat Oct 18 15:43:47 EDT 2014 System is up.
Sat Oct 18 15:24:25 EDT 2014 System is up.
Sat Oct 18 15:19:46 EDT 2014 System is up.
Sat Oct 18 15:06:10 EDT 2014 System is up.
Sat Oct 18 14:53:58 EDT 2014 System is up.
Sat Oct 18 14:41:24 EDT 2014 System is up.
Sat Oct 18 14:39:28 EDT 2014 System is up.
Sat Oct 18 14:29:46 EDT 2014 System is up.
Sat Oct 18 12:57:02 EDT 2014 System is up.
Sat Oct 18 12:46:27 EDT 2014 System is up.
Sat Oct 18 12:08:18 EDT 2014 System is up.
Sat Oct 18 11:33:52 EDT 2014 System is up.
Sat Oct 18 10:30:11 EDT 2014 System is up.
Sat Oct 18 09:20:40 EDT 2014 RAID sync started on volume C.
Sat Oct 18 09:03:52 EDT 2014 System is up.
Sat Oct 18 07:26:57 EDT 2014 System is up.
Sat Oct 18 06:56:58 EDT 2014 System is up.
Sat Oct 18 05:28:39 EDT 2014 System is up.
Sat Oct 18 05:10:00 EDT 2014 System is up.
Sat Oct 18 04:06:26 EDT 2014 System is up.
Sat Oct 18 03:34:03 EDT 2014 System is up.
Sat Oct 18 02:30:05 EDT 2014 System is up.
Sat Oct 18 02:08:15 EDT 2014 System is up.
Sat Oct 18 01:48:13 EDT 2014 System is up.
Sat Oct 18 00:41:20 EDT 2014 System is up.
Sat Oct 18 00:24:10 EDT 2014 System is up.
Sat Oct 18 00:13:11 EDT 2014 System is up.
Fri Oct 17 23:54:44 EDT 2014 System is up.
Fri Oct 17 23:41:06 EDT 2014 System is up.
Fri Oct 17 23:23:45 EDT 2014 System is up.
Fri Oct 17 23:11:32 EDT 2014 System is up.
Fri Oct 17 23:04:51 EDT 2014 System is up.
Fri Oct 17 22:41:13 EDT 2014 System is up.
Fri Oct 17 22:23:26 EDT 2014 System is up.
Fri Oct 17 21:46:52 EDT 2014 System is up.
Fri Oct 17 21:34:16 EDT 2014 System is up.
Fri Oct 17 20:51:20 EDT 2014 System is up.
Fri Oct 17 20:36:32 EDT 2014 System is up.
Fri Oct 17 20:24:42 EDT 2014 System is up.
Fri Oct 17 20:11:17 EDT 2014 System is up.
Fri Oct 17 19:51:37 EDT 2014 System is up.
Fri Oct 17 19:21:44 EDT 2014 System is up.
Fri Oct 17 19:02:11 EDT 2014 System is up.
Fri Oct 17 18:38:29 EDT 2014 System is up.
Fri Oct 17 18:36:42 EDT 2014 System is up.
Fri Oct 17 18:25:14 EDT 2014 System is up.
Fri Oct 17 18:10:41 EDT 2014 System is up.
Fri Oct 17 18:02:04 EDT 2014 System is up.
Fri Oct 17 17:48:25 EDT 2014 System is up.
Fri Oct 17 17:24:47 EDT 2014 System is up.
Fri Oct 17 17:04:04 EDT 2014 System is up.
Fri Oct 17 15:43:01 EDT 2014 System is up.
Fri Oct 17 15:14:31 EDT 2014 System is up.
Fri Oct 17 14:58:20 EDT 2014 System is up.
Fri Oct 17 14:31:44 EDT 2014 System is up.
Fri Oct 17 13:45:46 EDT 2014 System is up.
Fri Oct 17 13:26:11 EDT 2014 System is up.
Fri Oct 17 13:00:01 EDT 2014 Volume expansion or migration started. Do not interrupt the system during this time. When finished, email notification will be sent to the alert contact list.
Fri Oct 17 12:57:53 EDT 2014 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 3]
Fri Oct 17 12:57:34 EDT 2014 A disk was removed from the ReadyNAS.
Fri Oct 17 12:57:34 EDT 2014 Disk removal detected. [Disk 3]
Fri Oct 17 12:55:48 EDT 2014 Volume expansion aborted because the new drive has data. To override and continue with the expansion, hot-remove the drive, wait 10 seconds, and hot-add the drive. [Disk 3]
Fri Oct 17 12:55:46 EDT 2014 Volume expansion or migration started. Do not interrupt the system during this time. When finished, email notification will be sent to the alert contact list.
Fri Oct 17 12:53:55 EDT 2014 System is up.
Fri Oct 17 12:52:45 EDT 2014 Rebooting device...
Fri Oct 17 12:52:45 EDT 2014 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
Fri Oct 17 12:49:47 EDT 2014 RAID sync finished on volume C.
Fri Oct 17 05:29:41 EDT 2014 System is up.
Fri Oct 17 04:07:40 EDT 2014 System is up.
Fri Oct 17 03:33:05 EDT 2014 System is up.
Fri Oct 17 00:46:36 EDT 2014 System is up.
Thu Oct 16 21:30:39 EDT 2014 System is up.
Thu Oct 16 21:16:32 EDT 2014 System is up.
Thu Oct 16 18:10:13 EDT 2014 System is up.
Thu Oct 16 17:52:55 EDT 2014 System is up.
Thu Oct 16 17:22:45 EDT 2014 System is up.
Thu Oct 16 17:15:34 EDT 2014 System is up.
Thu Oct 16 17:08:01 EDT 2014 System is up.
Thu Oct 16 16:37:43 EDT 2014 System is up.
Thu Oct 16 15:57:06 EDT 2014 System is up.
Thu Oct 16 15:43:55 EDT 2014 System is up.
Thu Oct 16 15:29:34 EDT 2014 System is up.
Thu Oct 16 15:19:10 EDT 2014 System is up.
Thu Oct 16 15:12:55 EDT 2014 System is up.
Thu Oct 16 14:54:13 EDT 2014 System is up.
Thu Oct 16 14:39:58 EDT 2014 System is up.
Thu Oct 16 13:10:21 EDT 2014 System is up.
Thu Oct 16 11:12:24 EDT 2014 System is up.
Thu Oct 16 10:57:42 EDT 2014 System is up.
Thu Oct 16 10:37:26 EDT 2014 System is up.
- mdgm-ntgrNETGEAR Employee RetiredI wonder if the replacement power supply is compatible. When did you replace the PSU?
The NAS doesn't run a long disk test in normal mode and may not alway pick up problems with disks. A long test is done with the Disk Test boot menu option.
I would recommend running the Lifeguard extended test. - rklunderAspirantI replaced the power supply August 2013. I originally bought a SeaSonic SS-300SFD 300W SFX12V v3.1 80 PLUS Certified Active PFC Power Supply - OEM from new egg, but returned it and upgraded to a Silverstone Tek 450W SFX Form Factor Power Supply (ST45SF) for more available power. The SeaSonic part number matched what was in it originally if i recall correctly, the only problem was the stock cable lengths were to short and I had to add an extension cable to reach the motherboard.
- rklunderAspirantI ran the memory test overnight, no errors reported.
_Time___Prog_Pss_Err
08:43:11 100% _12 __0 - mdgm-ntgrNETGEAR Employee RetiredHave you started testing the disks yet?
- rklunderAspirantYes, so far no issues, but each one will take 13+ hours. I dont think the hard drives (mechanically) are the issue.
Understood, but it is still useful to know they passed the diagnostic.rklunder wrote: Yes, so far no issues, but each one will take 13+ hours. I dont think the hard drives (mechanically) are the issue.
BTW, I've had some drives pass the extended non-destructive test with flying colors, but fail when I ran the destructive write test. Though if that is provoking the resyncs, I'd expect to see something in the SMART stats.
Another option (after the diags are run) might be to schedule a disk scrub in the pro.
Was this a typo? (e.g., was it intended to be the same 1858 GB as the others??)Ch 6 : WDC WD20EFRX-68AX9N0 [1863 GB] 858 GB allocated - rklunderAspirantThat appears to be a typo. I think i did align the cut and pasted text which probably caused it. Below is an untouched cut and paste. BTW, all is working fine right now. I am running the extended test on the drive that was labeled as dead mentioned in the first post (which was replaced by disk 3 shown below). I would expect this drive to be the one to show issues since it was deemed dead by the readynas.
Disk space
1386 GB (18%) of 7394 GB used
RAID Configuration
Configuration: RAID Level X-RAID2, 6 disks
Status: Redundant
RAID Disks:
Ch 1 : WDC WD2003FYPS-27Y2B0 [1863 GB]
1858 GB allocated
Ch 2 : WDC WD2002FYPS-02W3B0 [1863 GB]
1858 GB allocated
Ch 3 : WDC WD20EFRX-68EUZN0 [1863 GB]
1858 GB allocated
Ch 4 : WDC WD20EFRX-68AX9N0 [1863 GB]
1858 GB allocated
Ch 5 : WDC WD20EFRX-68AX9N0 [1863 GB]
1858 GB allocated
1858 GB allocated - rklunderAspirantTesting the drive the readynas labeled as dead, which was replaced by drive 3 in the list above, yielded only 3 bad sectors all of which were recovered. Data life guard reported the drive as passed. In addition, this drive is currently running fine as an external USB drive.
