xtrips1
Aug 22, 2016Aspirant
ReadyNAS Pro will not power on
Hello, My NAS will not power on. This has happened only once in the past and somehow I managed to bring it up to life, after many scrares and efforts, and it worked more than 1 year straight, con...
xtrips1
Hello Stephen,
It looks like you know your stuff. Following my description of events, do you think there is a strong probability that the power supply is responsible?
Because if you think so, I can try and replace it. That would be an "economically" viable solution for me.
Along the years this NAS has become secondary, because it became full (15 TB) and I had to add another newer NAS.
But the data in it is very important to me and it has no backup. Where could I backup another 15 TB anyway?
BTW, for the moment I tried the first step, removing the HDDs, unsuccessfully.
I'll try the next one, moving it, tomorrow.
Thanks
Aug 22, 2016Guru - Experienced User
Does anything happen when you turn on the power? If you see no leds/nothing on the screen/no fan, then the power supply is likely the reason.
- xtrips1Aug 23, 2016Aspirant
The only thing that lits up are the Ethernet LEDs.
Power Supply you say....
Ok. It's logical.
I'll order one.
Thank you
