BlillyWill's avatar
Dec 02, 2022
Readynas Pro2 OS6 - copying config to second volume?
I need to shrink my array down to use 1TB SSDs from the existing 3TB raid 1 volume of which barely 500GB is used. I went down the MDADM rabbit hole and it's a little cryptic for me, so I am thinking ...
  • StephenB's avatar
    Dec 03, 2022
    BlillyWill wrote:
    How can I make sure the new 1TB SSD has the OS, apps and config copied to it? Theoretically, it should propagate on the next reboot correct? Would make sense so your nas doesnt reset to factory default if one of your volumes dies.
    The OS partition is already on the SSD (that is RAID-1 and mirrored on all disks).  The configuration is in that partition, so it is also on the SSD.
    As you know, apps are in a hidden folder on the data volume (/data/.apps) , so that is a bit tricky.
    If you destroy the 3 TB volume, the system will create a new apps folder on the SSD.  But it will not copy the contents of the old one.  What you could do is copy /data/.apps to a temporary share on the SSD, then copy it back to the SSD .apps folder after you destroy the 3 TB volume.
    If you use the home folder feature, you will need to do something similar - back up the home folder contents, and then restore them to the SSD.  Personally I don't think that feature is worth the trouble for home NAS users, so consider switching to using ordinary shares (with access control if needed).  Sandshark provided more info on migrating home folders here:
    For the shares, just create temporary shares with different names on the SSD volume, and copy the data over with backup jobs. Match the settings (file permissions, etc).  Then rename them to match the original names after you destroy the old volume.
    BlillyWill wrote:
    Or do I need to I just dumbly DD from /dev/sda to /dev/sdb and also the /apps mount point?
    I don't recommend that.
ProSupport for Business
