Bjohn1
May 02, 2018Aspirant
ReadyNas refusing to connect
Hi Folks,
I have, yes very old, ReadyNAS-NV. I think the last firmware update was V4.2.28.
I recently moved house and updated to windows 10, obviously not a good idea to do both at the same t...
- May 06, 2018
RAIDar shows that you have a NV+ v1 ReadyNAS running the current (and likely final) 4.1.16 firmware.
Try this on the win7 machine:
Run the command prompt (CMD). That will open a black text window.
type
net use * /delete
net use t: \\192.168.0.5\C /user:admin nas-admin-password
using the real admin password of the NAS of course. Be careful on the different slash directions and the spaces.
The first command will terminate any open network sessions. If it prompts, tell it to proceed. The second command attempts to mount the NAS data volume as drive letter T on the PC. Let us know what happens.
May 03, 2018Guru - Experienced User
NV and NV+ run 4.1.x firmware, and the final release for them was 4.1.16.
4.2.28 is for an x86 legacy NAS (pro or ultra). So lets start by confirming what you have. If you can give us the part number off the back (ends with -100XXX or -200XXX) that would be helpful. The XXX part is either NAS or a country-specific code.
Bjohn1 wrote:
Any, any suggestions/ comments/ help greatly appreciated (not at all technically minded)
Install RAIDar 4.3.8, and tell us what status it gives you: https://kb.netgear.com/20684/ReadyNAS-Downloads
Note that windows 10 can complicate accessing your NAS via windows file explorer, but it doesn't change accessing the web ui via Chrome. https://192.168.0.5/admin should work (though you will get a security warning that you need to click through). If that doesn't work, RAIDar might give us a clue as to why.
Also, are you seeing anything unusual on the LCD panel of the NAS?
