OldTimerGuy
Feb 08, 2020Aspirant
ReadyNAS reports not enough space
My ReadyNAS 524X reports (data shows a red bar) that there is only 481 GB available out of 8.17 TB of space. I have 4 3 TB drives installed in the unit, using RAID 5. I am running on a Mac. When ...
- Feb 09, 2020
Sandshark wrote:On the Volumes page of the GUI, you can see if some of that space is taken up by snapshots and you can also use the gear icon to do a balance. But it would be unusual for a balance to free up that much space.
Thank you for your comments, Sandshark. As a matter of fact, in my case, deleting snapshots and rebalancing did free up that much space. I don't know why it worked, but it did. :-)
Sandshark
Feb 08, 2020Sensei
Feb 08, 2020Guru - Experienced User
Yes. I think the first step is to see how much space is in snapshots.
OldTimerGuy are you using the NAS to store time machine backups?
- OldTimerGuyFeb 09, 2020Aspirant
No, I am not using the NAS to store Time Machine backups. I use an attached external hard drive. But deleting snapshots and rebalancing worked in my case. Thank you for your comments.
- SandsharkFeb 09, 2020Sensei
It is likely that the snapshot deletion was the main thing that released the free space. Reclaining of free space after deleting snapshots can take a while, and a balance will speed that up.
- OldTimerGuyFeb 10, 2020Aspirant
Sandshark wrote:It is likely that the snapshot deletion was the main thing that released the free space. Reclaining of free space after deleting snapshots can take a while, and a balance will speed that up.
Thank you, Sandshark. I will delete the snapshots more often now.
