RangeMethod
Jun 17, 2013Aspirant
ReadyNAS RN 104 Automatic FAN-Control
Hi All, I have a Big Problem with my New (2 Weeks old) ReadyNAS 104. When i have a look at the WEB-UI under the Performance TAB i see the FAN is always running at only ~875 rpm. After a fresh st...
dishmagic66
Jul 08, 2013Guide
I was fiddling with this too on my RN104. Even when the cpu reaches 70 degrees, the fan runs at 800rpm.
Fancontol works, but i don't know how to get the temparature sensor in the config.
I can see that it is located in /sys/devices/platform/axp-temp.0# cat temp1_input gives the temperature.
Next step is to make it work with lm-sensors or fancontrol, but i am kind a stuck here.
regards
regards
