RangeMethod
Jun 17, 2013Aspirant
ReadyNAS RN 104 Automatic FAN-Control
Hi All, I have a Big Problem with my New (2 Weeks old) ReadyNAS 104. When i have a look at the WEB-UI under the Performance TAB i see the FAN is always running at only ~875 rpm. After a fresh st...
dishmagic66
Jul 09, 2013Guide
I have 4 Seagate ST2000DM001 installed.
The high temperature occurs when moving large amount of data over Gbit lan to the nas and running Transmission at the nas at the same time.
When the nas is idling the cpu temp is about 55 degrees and the drives between 41 and 43 degrees. Again with 23 degrees room temperature.
To me the drive temperatures are not that shocking. but the cpu temp is, When playing with pwmconfig and the fan running at 1500 rpm then the cpu temp sinks below 50 under load and under 38 when idling.
Even when the fan is at 1000rpm during idle, the cpu temp stays around 45 degrees.
Regards
Regards
