RangeMethod
Jun 17, 2013Aspirant
ReadyNAS RN 104 Automatic FAN-Control
Hi All, I have a Big Problem with my New (2 Weeks old) ReadyNAS 104. When i have a look at the WEB-UI under the Performance TAB i see the FAN is always running at only ~875 rpm. After a fresh st...
aVe2000
Jul 25, 2013Aspirant
same problem here. I didnt get fancontrol to work, too. It does not only depends on the not detected temp sensor but i am also not able to set the fan speed to a higher value at all. My cpu temp was above 75 degree also.
Support told me that the fan speed spins up > 85 degree. That sounds crazy to me. I did start a support question to the cpu manufacturer marvell regarding valid temperature values. If i get an answer i will let you know...and of course netgear also.
I dont know why this is so hard to change by the user.
Regards
Regards
