RangeMethod
Jun 17, 2013Aspirant
ReadyNAS RN 104 Automatic FAN-Control
Hi All, I have a Big Problem with my New (2 Weeks old) ReadyNAS 104. When i have a look at the WEB-UI under the Performance TAB i see the FAN is always running at only ~875 rpm. After a fresh st...
mdgm-ntgr
Aug 08, 2013NETGEAR Employee Retired
Well as well as taking into account the CPU temp, the drive temps would be taken into account too, I think (assuming it is the same as with older models). So if the drives got over a certain temperature but the CPU was still < 85 degrees the fan should speed up anyway and if this still doesn't fix the issue the system should shutdown.
