RangeMethod
Jun 17, 2013Aspirant
ReadyNAS RN 104 Automatic FAN-Control
Hi All, I have a Big Problem with my New (2 Weeks old) ReadyNAS 104. When i have a look at the WEB-UI under the Performance TAB i see the FAN is always running at only ~875 rpm. After a fresh st...
Dec 28, 2013Guru - Experienced User
The google study xeltros referred to is here: http://static.googleusercontent.com/med ... ilures.pdf
Google found that disk failures due to temperature did not climb until > 40C. Note the 3-year data points in figure 5.
The study is dated (data was collected between December 2005 and August 2006, the oldest drives in the study were manufactured in 2002). I haven't seen anything similar published on modern drives though.
