RangeMethod
Jun 17, 2013Aspirant
ReadyNAS RN 104 Automatic FAN-Control
Hi All, I have a Big Problem with my New (2 Weeks old) ReadyNAS 104. When i have a look at the WEB-UI under the Performance TAB i see the FAN is always running at only ~875 rpm. After a fresh st...
dishmagic66
Dec 28, 2013Guide
I had to delete a tilde in /etc/init.d/fanoveride to make it work:
when it is:
then it works.
Temperature is more stable now.
Pushing 10GB to the nas and the fan spins at 1400 rpm and the temp is 58 degrees.
When Idling then it spins at 850 - 1000 rpm and the temp is 50 degrees.
Not bad if you ask me.
SCRIPT=~/fanoveride
RUNAS=root
when it is:
SCRIPT=/fanoveride
RUNAS=root
then it works.
