RangeMethod
Jun 17, 2013Aspirant
ReadyNAS RN 104 Automatic FAN-Control
Hi All, I have a Big Problem with my New (2 Weeks old) ReadyNAS 104. When i have a look at the WEB-UI under the Performance TAB i see the FAN is always running at only ~875 rpm. After a fresh st...
moseleypj
Dec 29, 2013Aspirant
The fact you had to remove a tilde means you're now launching the file from the root directory which isn't advisable. I placed the script in /root folder which is the home folder for root which is what the tilde refers to. Anyhow, it shouldn't make much difference. My setup is currently running at 45C and 930RPM at idle and about 52C and 1500RPM under load.
