RangeMethod
Jun 17, 2013Aspirant
ReadyNAS RN 104 Automatic FAN-Control
Hi All, I have a Big Problem with my New (2 Weeks old) ReadyNAS 104. When i have a look at the WEB-UI under the Performance TAB i see the FAN is always running at only ~875 rpm. After a fresh st...
moseleypj
Dec 29, 2013Aspirant
I forgot to add that if you want cooler operation or minimum noise you can do so by editing mainly the MINTEMP and MAXTEMP variables. The graph below shows two calibrations for both scenarios. Reducing both temperatures for a more conservative temperature results in the fan working faster across the range to move the operating temperature lower down the graph. Similarly for a quieter operation move the temperatures higher. Or if you're fancy, move just one of them :wink:
