ftr_nas
Dec 22, 2022Aspirant
ReadyNAS RN 104 volume fails (Firmware 6.10.8)
My ReadyNAS RN 104 doesn't work anymore. First it couldn't start. When booting, it stopped in the middle with booting and a percentage (Every booting try with a other number) After some tries...
Dec 22, 2022Guru - Experienced User
Do you have a backup of your files?
It would be helpful to download the log zip file from the logs page - it might give more details on what went wrong.
- ftr_nasJan 05, 2023Aspirant
mdstat.log
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md125 : active raid0 sdd3[0] sdc3[1]
7804599808 blocks super 1.2 64k chunks
md126 : active raid0 sdb3[0]
3902168832 blocks super 1.2 64k chunks
md127 : active raid0 sda3[0]
md0 : active raid1 sdb1[4] sda1[5] sdd1[1]
4190208 blocks super 1.2 [4/3] [UUU_]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Tue Dec 29 01:47:36 2015
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 3
Persistence : Superblock is persistentUpdate Time : Tue Dec 27 17:57:24 2022
State : clean, degraded
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Spare Devices : 0Consistency Policy : unknown
Name : 0e3707ca:0 (local to host 0e3707ca)
UUID : d3387fb8:c59ed4ac:2a5d06dd:e173dd82
Events : 54351Number Major Minor RaidDevice State
4 8 17 0 active sync /dev/sdb1
1 8 49 1 active sync /dev/sdd1
5 8 1 2 active sync /dev/sda1
- 0 0 3 removed
/dev/md/DVD-0:
Version : 1.2
Creation Time : Mon Dec 28 20:38:15 2015
Raid Level : raid0
Array Size : 7804599808 (7443.05 GiB 7991.91 GB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistentUpdate Time : Mon Dec 28 20:38:15 2015
State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0Chunk Size : 64K
Name : 0e3707ca:DVD-0 (local to host 0e3707ca)
UUID : bdd9dd6e:460b18e1:76bfafd8:e827ca5a
Events : 0Number Major Minor RaidDevice State
0 8 51 0 active sync /dev/sdd3
1 8 35 1 active sync /dev/sdc3
/dev/md/DVD-1:
Version : 1.2
Creation Time : Sat Dec 24 12:41:16 2016
Raid Level : raid0
Array Size : 3902168832 (3721.40 GiB 3995.82 GB)
Raid Devices : 1
Total Devices : 1
Persistence : Superblock is persistentUpdate Time : Sat Dec 24 12:41:16 2016
State : clean
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Name : 0e3707ca:DVD-1 (local to host 0e3707ca)
UUID : fb057a48:933d8bff:b3bb6d40:b45c8091
0 8 19 0 active sync /dev/sdb3
/dev/md/DVD-2:
Version : 1.2
Creation Time : Sat Dec 24 12:51:33 2016
Raid Level : raid0
Raid Devices : 1
Total Devices : 1
Persistence : Superblock is persistentUpdate Time : Sat Dec 24 12:51:33 2016
State : clean
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Name : 0e3707ca:DVD-2 (local to host 0e3707ca)
UUID : b4de1ab1:b55a9bfb:5d6852a7:c46237a7
0 8 3 0 active sync /dev/sda3- StephenBJan 05, 2023Guru - Experienced User
ftr_nas wrote:
mdstat.log
3902168832 blocks super 1.2 64k chunksThis suggests you had three volumes - two JBOD (sda and sdb), and one RAID-0 (spanning sdc and sdd).
Looks like DVD-0 is the RAID-0 volume, with the two jbod volumes being DVD-1 and DVD-2.
Is this correct? (not sure it is)?
4190208 blocks super 1.2 [4/3] [UUU_]This suggests something is wrong with sdd. Though it does still seem to be in DVD-0.
Are you seeing any disk errors in system.log, kernel.log, or systemd-journal.log? Or btrfs errors?
- ftr_nasJan 09, 2023Aspirant
No, I had only one volume with the name dvd.
First a RAID0 with two disks and later with four disks.
system.log errors (several times):
Dec 21 14:57:37 DVDs wsdd2[2199]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Dec 21 14:57:37 DVDs wsdd2[2199]: error: wsdd-mcast-v6: wsd_send_soap_msg: sendkernel.log errors (several times):
Dec 26 20:01:27 DVDs kernel: sd 2:0:0:0: [sdc] tag#3 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Dec 26 20:01:27 DVDs kernel: sd 2:0:0:0: [sdc] tag#3 CDB: Read(16) 88 00 00 00 00 00 00 8f ff c0 00 00 00 08 00 00
Dec 26 20:01:27 DVDs kernel: blk_update_request: I/O error, dev sdc, sector 9437120
Dec 26 20:01:27 DVDs kernel: sd 2:0:0:0: [sdc] tag#4 FAILED Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Dec 26 20:01:27 DVDs kernel: sd 2:0:0:0: [sdc] tag#4 CDB: Read(16) 88 00 00 00 00 00 00 8f ff c0 00 00 00 08 00 00
Dec 26 20:01:27 DVDs kernel: Buffer I/O error on dev sdc2, logical block 131056, async page read
Dec 26 20:01:27 DVDs kernel: Buffer I/O error on dev md125, logical block 1951149936, async page read
Dec 26 20:01:27 DVDs kernel: Buffer I/O error on dev md125, logical block 1951149936, async page readIn the systemd-journal.log the smae errors like errors in kernel.log.
I can't find errors in btrfs.log
How can I post longer text here?
I tried several times with 6, 4, 2 and 1 log-files.
It's not the length - they are getting caught by the automatic spam filter.
I released the one from earlier today - wasn't sure if releasing the older ones made sense or not.
