RupertGiles
Apr 05, 2018Apprentice
ReadyNAS RN 314 OS 6.9.3 HTTPS configuration
RN314 OS 6.9.3 After upgrading to OS 6.9.3, the admin page wouldn't load in Chrome. I suspect this is due to a cache issue, because it loads okay with other browsers. HOWEVER, it appears that un...
- Apr 05, 2018
Hi RupertGiles
You are right :)
Clearing cache will help resolve the issue on accessing the admin page.
There has been a fix as well you just need to connect your NAS to the internet and reboot it and wait for a few minutes for it to be applied.
Regards
RupertGiles
Never Mind :smileyhappy:
I have noted in the support documents that HTTPS cannot be disabled. I probably need to clear the cache in Chrome, which is painful. However, HTTPS access works perfectly in Firefox and Safari.
- Jul 08, 2018Retired_Member
