spock1189
Oct 23, 2020Aspirant
ReadyNAS RN102 setup issues
Hi, Really hoping somebody can help me work out whats going on with my RN102, which is loaded with 2x500GB disks. I was looking for a basic NAS to use with Plex as a music server, and this one s...
Sandshark
Oct 23, 2020Sensei
If the NAS is invisible to RAIDar without drives, it's not the drives that are the main problem (though they may still be a secondary one). You either have no connection to the NAS over Ethernet, possibly because of bad hardware in between and possibly because something on your PC is blocking the traffic, or the NAS is broken. You can pursue checking if the drives are OK using a PC and also removing any partitions on them (the NAS can't deal with system reserved partitions created by Windows), but that's not going to fix the connectivity issue.
Oct 23, 2020Guru - Experienced User
And you really should resolve this before you do anything with the drives.
Check the LED status on the NAS NIC and also on the router/switch (if the router/switch has LEDs). Also check your router's device list, and see if you see an IP address for the NAS.
On the PC, disable any internet security software (Windows firewall, Kasperksy, Avast), and see if that makes any difference.
- spock1189Oct 23, 2020Aspirant
Thanks again both of you. Here we go:
My ethernet cable is the only one I have, its a short cable and I've used it with another device in the last 7 days with no issues - 99.9% confident its not broken. Nobody else has touched it.
I've powered the NAS on, no drives installed and I've got a green blinking (blinking intermittently) light on the NAS ethernet port. No amber. From the manual:
Green blinking, amber off. 1000 Mbps connection speed, activity.
Green on, amber off. 1000 Mbps connection speed, no activity.
Router does not have lights on the ports (its a BT home hub). Logging into the router and looking at the device list I see nothing connected to port 2 (where the NAS should be). I tried swapping the connection for my Sonos system from port 1 to port 2, and put the NAS where the Sonos was... now the Sonos shows in port 2 but nothing from the NAS in port 1. So it looks like the router isnt recognising the NAS, but its fine if you plug something else in.
So... something in my router settings doesn't agree with the NAS?
- StephenBOct 23, 2020Guru - Experienced User
Can you try connecting the NAS directly to a PC? Then see if RAIDar (running on the same PC) can see it.
Just tried this. Connected the ethernet cable from the NAS to my PC and booted up the NAS (still diskless). The PC recognised an ethernet network and labelled it "unidentified network - no internet access" but RAIDar did not see it. I tried again, this time with my wireless connection from the router to the PC disabled, with the same result. I guess this shows that there is something being communicated along the ethernet cable?
