EddyV
Jul 21, 2016Aspirant
ReadyNas RN104 hangs after FW-upgrade 6.5.1 with 99% booting
Hi all, A week ago I've upgraded our ReadyNas 104 from v6.5.0 to v6.5.1 After reboot the NAS hangs on 99% booting... couple of days later pulled out the powerconnector (Powerbutton doesn't react), ...
- Aug 03, 2016
Each firmware release is QA tested, but in the unlikely event you run into problems after a firmware update it's nice to know that as a last resort you can restore from backup. It's best practice to update your backup before installing the firmware update.
You can choose not to install firmware updates however you would miss out on new features, bug fixes, security updates and other enhancements. If you contact support about a minor software issue and you are running old firmware one of the first suggestions is likely to be to update the firmware.
Jul 21, 2016Guru - Experienced User
Did you try booting in read-only mode?
EddyV
Jul 22, 2016Aspirant
Yesss this works for now...
It ttok a while before I got some time to try this.
At ths moment the Nas is running in Readonly Mode through the network, Backup is running to get the many TB's in a save place.
Do you have a got suggestion what to do next?
Is factory default the only option?
- JennCJul 23, 2016NETGEAR Employee Retired
Hello EddyV,
Have a full backup first then check in the admin page if the FW really updated. You might need to factory reset.
- JennCJul 26, 2016NETGEAR Employee Retired
Hello EddyV,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- EddyVJul 26, 2016Aspirant
I'm sorry, but the moment of solution is still at work...
The backup is still running for days now. Nearly 8TB of data takes a long time to get it in save place.
At this moment there's 20% to go... After that I'm gonna reset to factory defaults as JennC suggested.
I will let you all know what happened after that action...
Regards, EddyV
- JennCJul 27, 2016NETGEAR Employee Retired
Hello EddyV,
Alright. Let us know.
