nathor's avatar
nathor
ReadyNAS RN104 Slow
My ReadyNAS RN104 was recently at under 5% capacity, before I purchased another disk. However, since installing that new disk, the NAS is running very slowly, specifically with transfer speeds. This ...
  • Marc_V's avatar
    Jul 29, 2019
    nathor
    Yes, you should do volume maintenance and you can actually set a schedule for it to run automatically. You may check the different maintenance on this article. To setup maintenance schedule, you can check it here. The slow performance might also be because of the ReadyNAS still syncing the disk at the time.
    Also, we don't really recommend using the NAS as the only means of backup for your data, the NAS or RAID can help you avoid or recover from failures and while you can store backups of your data on the NAS it is still advisable to keep at least 2 to 3 copies on different storage. IMO, keeping more copies the better  :)
    HTH
    Regards
ProSupport for Business
