Steven-K
Feb 27, 2022Aspirant
ReadyNas RN212 Powers Up but Not Responsive or Accessible
I have a ReadyNas RN212 that suddenly became inaccessible on the network. None of the computers on the network can "see" the ReadyNas. I attempted to shut down gracefully and reboot, but was unable...
Steven-K
I have removed both disks and powered the unit back up. All 4 lights on the front light up (including the Disk 1 and Disk 2 lights even though there are no disks in the chassis). The unit does not show up on my network. I have run Discover under ReadyCloud and still nothing shows up. I can't get RAIDar to run. It's looking for OpenJDK version 11 or higher even though I have installed OpenJDK version 17.0.2.
Feb 28, 2022Guru - Experienced User
This is RAIDar 6.5?
- Steven-KFeb 28, 2022Aspirant
Yes, it is RAIDar 6.5. Attached is a Word document showing:
- The RAIDar and OpenJDK files that I downloaded yesterday
- The RAIDar pop-up error message that I receive when trying to launch RAIDar
- The cmd prompt screen showing the OpenJDK version that is now running
- StephenBFeb 28, 2022Guru - Experienced User
Interesting - looks like a bug that Netgear will need to fix. Marc_V or JeraldM: could you kindly escalate this?
FWIW, my own Win10 systems show this:
java -version java version "1.8.0_201" Java(TM) SE Runtime Environment (build 1.8.0_201-b09) Java HotSpot(TM) Client VM (build 25.201-b09, mixed mode)
I don't recall installing it (though it is signed by Oracle). This version works with RAIDar 6.5
I have one Win11 machine that didn't have Java installed. I got openjdk 17.0.2 (x64 MSI installer) from https://www.oracle.com/java/technologies/downloads/#jdk17-windows That gives me the same error you are getting.
- SandsharkFeb 28, 2022Sensei
Is the LED on the Ethernat port lit?
Unfortunately, your problem sounds like one with the +3.3VSB (3.3 volt standby) within the NAS, as it powers both the power on/off and NIC circuits. If that's it, there is a remote chance that a new power brick will make a difference, but there is no repair available. FYI, that voltage is always on, even with the NAS is "off", so it's one that goes bad a lot, especially if the NAS has been allowed to get too hot when "off".
Work with StephenB on other things, as I could be wrong, but you may be looking at the need for a replacement NAS.
