Craigc_D2
Jun 05, 2017Aspirant
ReadyNAS RN312 upgraded to 6.7.4, mapped drive folders and files not accessible
So I'm a little bit furious. Some at myself and some at Netgear. I upgraded from 6.5.2 to 6.7.4 and now when I try to access my shared files locally via the mapped drive I get "Shared is not accessib...
mdgm-ntgr
Jun 05, 2017NETGEAR Employee Retired
A direct upgrade from 6.5.2 (or later) to 6.7.4 is what is recommended. The UI prompts you with the recommended upgrade.
Can you send in your logs (see the Sending Logs link in my sig)?
Welcome to the Community!
- Craigc_D2Jun 05, 2017Aspirant
Logs uploaded.
- StephenBJun 05, 2017Guru - Experienced User
There have been some changes in how guest access works in the NAS - which were needed due to some changes in windows behavior. They might be causing your problem.
So in addition to sending in logs to mdgm... If you are using Windows - can you run CMD and then enter
net use * /delete
net use t: \\nas-ip-address\data /user:admin nas-admin-password
Use the real values for the stuff in italics, and be careful on spaces and slash direction. Also, if you aren't using XRAID, then replace "data" with the name of one of your data volumes.
These commands should mount the NAS data volume as drive letter t: The first one sometimes asks for confirmation (if so, let it proceed). Otherwise it will tell you that there are no sessions to close - you can ignore that.
- mdgm-ntgrJun 06, 2017NETGEAR Employee Retired
So you're running Egnyte? There seems to be a problem with an Egnyte upgrade.
