map71
Jul 27, 2014Aspirant
ReadyNAS RN316 + Seagate ST3000DM001
I've just got a ReadyNAS RN316 and have upgraded the firmware to 6.1.8. I have some drives; one 4TB WD drive and one 3TB Seagate ST3000DM001. My understanding is that you should start an X-RAID2 with ...
Jul 27, 2014Guru - Experienced User
You want an unformated disk.
map7 wrote: When I created a new partition table it removed all the partitions. I have tested msdos and gpt
Try deleting any existing disk volume from Windows, and then don't create anything. Or use the seatools write zeros diagnostic.
