map71
Jul 27, 2014Aspirant
ReadyNAS RN316 + Seagate ST3000DM001
I've just got a ReadyNAS RN316 and have upgraded the firmware to 6.1.8. I have some drives; one 4TB WD drive and one 3TB Seagate ST3000DM001. My understanding is that you should start an X-RAID2 with ...
Jul 28, 2014Guru - Experienced User
The WDC 4 TB drive was removed, so only the ST3000DM001 was installed
What happens if you simply boot up with only the zero'd ST3000DM001 installed? There's no need to select factory reset from the front panel, since that is the only option anyway.
