map71
Jul 27, 2014Aspirant
ReadyNAS RN316 + Seagate ST3000DM001
I've just got a ReadyNAS RN316 and have upgraded the firmware to 6.1.8. I have some drives; one 4TB WD drive and one 3TB Seagate ST3000DM001. My understanding is that you should start an X-RAID2 with ...
mdgm-ntgr
Jul 29, 2014NETGEAR Employee Retired
When the firmware on the internal flash is corrupt then you can get errors like the error you got or the NAS may hang while booting or run but with some services missing. This problem is usually only seen when you do a factory default as when you do a firmware update or OS Re-install the NAS can fall back to taking advantage of the copy of the firmware on the internal disks.
