Hakan71
Feb 25, 2017Aspirant
ReadyNAS RNDU 2120 Ultra 2 not Responding
When connected to power supply my readynas ultra 2 is just running at full speed with the fan, but it does not boot at all. I'm not able to reset it or anything. The blue power button is just lit and ...
- Apr 11, 2017
SOLVED!
I downloaded ReclaiMe Ultimate, great tool. All files have been saved.
Thanks for all support.
Håkan
Retired_Member
Feb 26, 2017In case you have put the power plug into any kind of extension lead and/or behind a usv (uninteruptable power supply), now just directly plug it into a power socket in the wall and try again.
