Hakan71
Feb 25, 2017Aspirant
ReadyNAS RNDU 2120 Ultra 2 not Responding
When connected to power supply my readynas ultra 2 is just running at full speed with the fan, but it does not boot at all. I'm not able to reset it or anything. The blue power button is just lit and ...
- Apr 11, 2017
SOLVED!
I downloaded ReclaiMe Ultimate, great tool. All files have been saved.
Thanks for all support.
Håkan
Hakan71
Feb 28, 2017Aspirant
Thanks for all input. I plan to try the disc to PC option next week.
Hakan71
Apr 09, 2017Aspirant
Summury so far = have still not manage to recover the ReadyNAS files.
I downloaded r-linux to my PC, then scanned one of the ReadyNAS discs via a SATA docking station. Two volumes were "recognized" (took quite some hours to scan): Ext3 and Ext4. There were also a few other partitions (believe it said they had unreadable format)
Both the recognized volumes each had a ROOT and a METAFILES folder. Only the Ext3 ROOT folder had sub-folders and files that were readable/understandable to me (e.g. bin, c, dev, etc, frontview, home, initrd, lib, lib64, root, sbin, sys, temp, etc). I recon these files were original ReadyNAS folders and programs. The Ext4 ROOT consisted only of files named like "$Inodelndx000038f8". The ext4 METAFILES folder consisted of lots of files named like "$BlockBitmap0000.bin", "$BlockBitmap0001.bin", etc.
I dont know what I should do next. Any suggestions?
