Hakan71
Feb 25, 2017Aspirant
ReadyNAS RNDU 2120 Ultra 2 not Responding
When connected to power supply my readynas ultra 2 is just running at full speed with the fan, but it does not boot at all. I'm not able to reset it or anything. The blue power button is just lit and ...
- Apr 11, 2017
SOLVED!
I downloaded ReclaiMe Ultimate, great tool. All files have been saved.
Thanks for all support.
Håkan
Hakan71
Apr 09, 2017Aspirant
Summury so far = have still not manage to recover the ReadyNAS files.
I downloaded r-linux to my PC, then scanned one of the ReadyNAS discs via a SATA docking station. Two volumes were "recognized" (took quite some hours to scan): Ext3 and Ext4. There were also a few other partitions (believe it said they had unreadable format)
Both the recognized volumes each had a ROOT and a METAFILES folder. Only the Ext3 ROOT folder had sub-folders and files that were readable/understandable to me (e.g. bin, c, dev, etc, frontview, home, initrd, lib, lib64, root, sbin, sys, temp, etc). I recon these files were original ReadyNAS folders and programs. The Ext4 ROOT consisted only of files named like "$Inodelndx000038f8". The ext4 METAFILES folder consisted of lots of files named like "$BlockBitmap0000.bin", "$BlockBitmap0001.bin", etc.
I dont know what I should do next. Any suggestions?
Apr 09, 2017Guru - Experienced User
This is the OS partition, not the data volume.
You could try a different software package. Several people have had good luck with ReclaiMe, though it is expensive. You can see what it can recovery before you buy though.
Netgear's recovery service is another possibility: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service?cid=wmt_netgear_organic
- Hakan71Apr 09, 2017Aspirant
I am currently scanning with ReclaiMe. Looks like this software is able to read the files - I can mid-run already preview a few photos and movies...looks promising, though as you say expensive. Thank you.
From r-tt page:
"R-Linux uses the same InteligentScan technology as R-Studio, and flexible parameter settings to provide the fastest and most reliable file recovery for the Linux platform. However, unlike R-Studio, R-Linux cannot recover data over network or reconstruct RAIDs, or provide object copy."
Thus, looks like I need R-studio to recover the ReadyNAS files using r-tt software. This software costs 79.99 USD.
If going with ReclaiMe, which of below two package do I need to purchase?
ReclaiMe File Recovery Standard - to recover data from Windows PCs $79.95
- Recovers files from Windows discs (FAT, exFAT, NTFS and ReFS)
OR
ReclaiMe File Recovery Ultimate - to recover Windows and Linux PCs, Macs, and NASes $199.95
- Recovers all files from Windows disks (FAT, exFAT, NTFS, and ReFS).
- Recovers all files from Apple Mac OS disks ( UFS, HFS, and HFS+).
Note: ReclaiMe File Recovery runs on Windows PCs, not Macs. To recover a Mac disk, you need to connect it to a Windows PC first. - Recovers all files from Linux ext2, ext3, ext4, BTRFS and XFS filesystems.
- Hakan71Apr 11, 2017Aspirant
SOLVED!
Håkan
