miogpsrocks
Jun 30, 2018Tutor
Readynas seem kind of slow, How do I check volume, scan hard drive,etc.?
Firmware 6.9.2 Readynas Pro
4TB drives X 6 bays.
15% disk space free.
Thanks.
- Jun 30, 2018
You need to be on System/Volumes tab and double click the "Gearwheel" on the left
Jun 30, 2018Guru - Experienced User
Try benchmarking the speed with Nastester: http://www.808.dk/?code-csharp-nas-performance
There are several maintenance functions on the volume settings wheel (balance, disk test, scrub, and defrag).
miogpsrocks
Jun 30, 2018Tutor
Are the maintenance functions such as balance, disk test, scrub and defrag part of the Nastester program or something that should be there already?
I do not see these fuctions Xraid, format, global spare, new volume are teh only options I see.
Please advice.
- bedlam1Jun 30, 2018Prodigy
You will find the maintenance functions if you click on the "gearwheel" shown in the box on the left of your screenshot
- miogpsrocksJun 30, 2018Tutor
Click on the file to get a detailed screen shot.
There are services, update, configuration & backup, alerts, support but not option to scan the hard drive for errors, defrag or any other option?
Please advice.
