MarkusX0
May 18, 2016Tutor
ReadyNAS shown on network but not accessible after upgrade to OS 6.5.0
I upgraded the OS today and got the ReadyCLOUD changeover completed to day successfully, however when I try to access the NAS through the 'Network' ( intranet ), it says that the device is inaccessib...
- May 31, 2016Yeah I have it sorted out for now... Dropping the ReadyCLOUD service for now. Rebooting clears it out too.
MarkusX0
May 18, 2016Tutor
My system does not have anything called Samba.. and as I mentioned above I do not have anything under the logs error it otherwise pointing to the cause of the problem... Not really for sure what Samba is exactly..
- StephenBMay 18, 2016Guru - Experienced User
MarkusX0 wrote:
My system does not have anything called Samba.. and as I mentioned above I do not have anything under the logs error it otherwise pointing to the cause of the problem... Not really for sure what Samba is exactly..Samba is the linux package that provides SMB access (e.g., Windows Network Shares). So he is suggesting that you go to system->settings and turn off the SMB service (and then turn it back on again).
- mdgm-ntgrMay 18, 2016NETGEAR Employee Retired
jak0lantash meant the SMB protocol under System > Settings > Services.
