MarkusX0
May 18, 2016Tutor
ReadyNAS shown on network but not accessible after upgrade to OS 6.5.0
I upgraded the OS today and got the ReadyCLOUD changeover completed to day successfully, however when I try to access the NAS through the 'Network' ( intranet ), it says that the device is inaccessib...
- May 31, 2016Yeah I have it sorted out for now... Dropping the ReadyCLOUD service for now. Rebooting clears it out too.
jaybepr
May 20, 2016Tutor
May 20, 2016Guru - Experienced User
What happens if you try using the NAS IP address instead of its name?
- dadnet55May 20, 2016Aspirant
Hi, I have tried the IP address instead of the ReadyNAS name & I get this error.
(I also lost my Windows mapped drive connection when I upgraded to 6.5.0)
As with other members, If I logon into the Readycloud web page, I can see & talk to the NAS. See screenshot from my Readycloud page.
So it sure looks like something in the 6.5.0 upgrade has knocked out Microsoft Windows file mapping.
I also updated the Readycloud app on my iphone & ipad, & they don't work either. They start up & then close pretty much straight away.
Something's not right.
Cheers,
David
- StephenBMay 20, 2016Guru - Experienced User
We might have multiple problems here - it can be confusing when multiple posters are sharing their symptoms on the same thread.
I suggest that it would be useful for jaybepr to report his experience using the IP address.
I am not seeing these symptoms with direct SMB access to either my RN102 or my RN202. Neither has ReadyCloud enabled, so I can't check that.
- MarkusX0May 21, 2016Tutor
Okay so I have still not found a solution to this problem... other than scrapping a $1,700.00 NAS... and $1,400.00 in Enterprise HDD... :(
I just tried reinstalling the OS and also to see if I could back up my configuration ( all through the browser ).. so that I could possibly install the previous firmware...
Neither attempt worked... Left with one option here only and that is to do factory default which will wipe the data from the disks... ( which actually I cannot afford to loose the data.. split it up would be okay.. as in removing the raid... but I cannot actually loose the data.. for any reason at all.. period )
SO.. anyone else found a solution or a work around to get these back online? OR...is all of data being held for ransom right now? :P
