MarkusX0
May 18, 2016Tutor
ReadyNAS shown on network but not accessible after upgrade to OS 6.5.0
I upgraded the OS today and got the ReadyCLOUD changeover completed to day successfully, however when I try to access the NAS through the 'Network' ( intranet ), it says that the device is inaccessib...
- May 31, 2016Yeah I have it sorted out for now... Dropping the ReadyCLOUD service for now. Rebooting clears it out too.
FabianGabor
May 24, 2016Initiate
I had the same issue. After days of trial and error I finally just managed to access my 102. You have to log out from your network.
To do this, go to:
Control Panel -> User Accounts -> Manage your credentials -> Windows Credentials
Here, delete anything related to your network drive. I had to delete 2 credentials. After that, try to access your NAS by either name or IP. It should ask you to log in again, do it with your upgraded ReadyCloud email address and password.
PS. I don't know if it's required but I also did open a Command Prompt and disconnected every remote connection by typing:
net use * /delete
Hope I could help!
NSDias
May 24, 2016Tutor
Thanks for the hint!
Unfortunately it is not working for me. I tried following those steps, and also even changing the IP asdress of the NAS. It did finally asked for new credentials, I've loged in the the new global ReadyCloud email and password, but it does not accept the login (I know it is the correct one, works on the win7 machine), and after 3 atampts it says it cannot access, just like before....
