MarkusX0
May 18, 2016Tutor
ReadyNAS shown on network but not accessible after upgrade to OS 6.5.0
I upgraded the OS today and got the ReadyCLOUD changeover completed to day successfully, however when I try to access the NAS through the 'Network' ( intranet ), it says that the device is inaccessib...
- May 31, 2016Yeah I have it sorted out for now... Dropping the ReadyCLOUD service for now. Rebooting clears it out too.
Mitch59
May 24, 2016Aspirant
Hello, to find my access SMB my NAS OS 6.5.0, I put the same email address and same password on my windows session and readycloud.
- JennCMay 24, 2016NETGEAR Employee Retired
Hello NSDias,
If you have ReadyCloud app installed and logged in, this will open Windows credentials using the ReadyCloud login.
Can you try logging it out and remove Everyone from one of the shares then use the net use command in the DOS prompt. Then try to map the NAS IP again and login as admin.
- NSDiasMay 25, 2016Tutor
Hi JennC,
Thank you for the suggestion.
I do not have any ReadyCloud app installed. But anyhow I followed your steps. Several shares are without the "Everyone" access, I used the net use command (retrieved no connections), checked that no credentials are associated with the NAS name or IP, and tried to map again. Still doesn't work on the win10 machine. No problems on win7.
I don't really want to create a new email account and have to change the Netgear ReadyCloud login and email associated... But all my home machines use win10, and not being able to acess with SMB after the FW update is crazy.
Any other ideas?
Thanks again
- Maximus360May 25, 2016Guide
Hi Guys
I am experiencing the same issues after upgrade to 6.5.0. I am unable to access my shares using SMB with the admin account on windows 10. I have no users setup on my NAS as i am the only user the only user is the default admin.
Does anyone know if you can roll back to 6.4 firmware as 6.5.0 just seems a complete failure altogether. I have removed my readycloud account from my NAS and i still cannot access shares. Although i can access everything as normal from my windows 7 machine.
Would love to know if there is a fix.
