Kakik5280
Nov 17, 2015Aspirant
ReadyNAS Ultra 2 boot problem
Hello there, I've bought a ReadyNAS Ultra2 3 years ago and I didn't have any problem with it until now. It don't boot anymore. I'll try to explain clearly. I can power it on, fan seems t...
- Nov 24, 2015
Hello JennC,
Thanks for the answer but I got the data using Linux Reader.
Therefore I've tried to format the 2 drives with the Default factory boot mode but it was running for more than 24 hours and never finished.
I tried to format drive into my computer with windows disk manager and I succeed.
I assume the HDD are ok and the NAS should be dead.
Thanks for your time.
Nov 17, 2015Guru - Experienced User
If you start up the NAS with no disks installed, does RAIDar see it? If not, you have a more basic hardware problem (perhaps a bad NIC) and the OS reinstall wouldn't help.
Check your warranty status right away - the ultra warranty is 3 years, and if you are lucky you might have a few weeks left.
