Kakik5280
Nov 17, 2015Aspirant
ReadyNAS Ultra 2 boot problem
Hello there, I've bought a ReadyNAS Ultra2 3 years ago and I didn't have any problem with it until now. It don't boot anymore. I'll try to explain clearly. I can power it on, fan seems t...
- Nov 24, 2015
Hello JennC,
Thanks for the answer but I got the data using Linux Reader.
Therefore I've tried to format the 2 drives with the Default factory boot mode but it was running for more than 24 hours and never finished.
I tried to format drive into my computer with windows disk manager and I succeed.
I assume the HDD are ok and the NAS should be dead.
Thanks for your time.
JennC
Nov 19, 2015NETGEAR Employee Retired
Hello Kakik5280,
ReadyNAS formats drives to EXT3. To recover data from the drive/s you may need to mount it to a Linux computer. This procedure is beyond NETGEAR scope of support as they do not have training for this since you will be dealing with the disks/drive's settings.
You may also check post of Dekkit on the forum link below as a guide:
Kakik5280
Nov 24, 2015Aspirant
Hello JennC,
