Rumpole
Jan 30, 2019Aspirant
Readynas Ultra 2 failing. Memory test led codes please.
Ultra 2 not working. visible in Raidar but cannot be browsed. Reinstalled OS and got an IP that worked (the default 192.168.168.168 would not accept incoming even when PC changed to 192.168.168.x) a...
Jan 31, 2019Guru - Experienced User
No idea on the memory test LED indication.
Did you try downloading the log zip file?
Rumpole wrote:
Netgear no longer seem to be supporting Logitech media server
Netgear never supported it. It was always a third party app, and not warranted or supported by Netgear. As I think I've already said on another thread, there is an LMS app availailable for OS-6 on apps.readynas.com.
Rumpole
Jan 31, 2019Aspirant
I will have look there for LMS and see if can find someone using it.
There were no log files, as in nothing at all. Slightly weird but Could be because I reloaded OS. I’m still suspicious of the memory module though as it simply failed to write anything from frontview. Disks seem to be ok (no errors reported on either and would be odd if both failed at once). The whole thing was coated in thick dust which may not have helped. Does live in a room with a log burner......
