alphapapa
Mar 21, 2015Aspirant
ReadyNAS Ultra 2 LAN slow
Ciao. I have a Readynas Ultra 2 with 2x WD RED 3 TB. I used to have the HDs in a Raid 0 configuration... but few days ago without warning I have lost everything. My previous configuration was the...
vandermerwe
Mar 21, 2015Master
Not exactly.
If your wifi router is 192.168.1.50, then your other LAN devices would normally have IP addresses in the format 192.168.1.x. Your gateway is not the wifi router, or is it?
Perhaps if the gateway is really 192.168.168.1, then setup your whole LAN like that, with IP address as 192.168.168.x.
Having said that, you have setup a direct PC to nas connection so this would appear to rule out the IP addresses or wifi being the problem.
How did you test the drives?
What firmware is on the nas?
