alphapapa
Mar 21, 2015Aspirant
ReadyNAS Ultra 2 LAN slow
Ciao. I have a Readynas Ultra 2 with 2x WD RED 3 TB. I used to have the HDs in a Raid 0 configuration... but few days ago without warning I have lost everything. My previous configuration was the...
alphapapa
Mar 26, 2015Aspirant
SOLVED!
For some reasons I do not know... I have decided to put back OS6.
I did the same exact steps I did before to instal it and I have used the same LAN connection with the same IP values.
But this time LAN transfer rate is 80 MB/s!!!
I guess was something in the NAS config, since the PC hasn't changes... maybe all those 'factory reset' I did solved the problem..
Thanks again for the support!!!!!!!!
