SATKABEL
May 16, 2012Follower
ReadyNAS Ultra 2 Plus died after firmware update Case #18610
Hello, I bought a ReadyNAS Ultra 2 Plus some weeks ago and it worked without any problems. Until I decided to upgrade the firmware with the latest RAIDiator version RAIDiator-x86-4.2.20. Now i...
mdgm-ntgr
May 16, 2012NETGEAR Employee Retired
If within 90 days of purchase, give tech support (http://www.readynas.com/support) a call. Otherwise open an online case. Edit the thread title (i.e. subject of first post in the thread to include your case number.
Yes there is USB Boot Recovery for x86 but this is a last resort as there is a possible negative side effect that would require a NetGear tech to remotely login to fix.
See what support has to suggest.
