DaveSh's avatar
DaveSh
Tutor
Sep 07, 2015
ReadyNAS Ultra 2 Plus Won't Boot
Hi All,   I have the above machine for home use (about 3 yrs old) + offsite backup from my office RN312. All has been working sweetly for a couple of years with no dramas to speak of.   A few day...
  • JennC's avatar
    JennC
    Sep 09, 2015
    Hello DaveSh,
    Thanks for the response.
    If you want to switch to XRAID2, make sure you have full back up of the files  if you can still access the volume as it requires factory reset.
    As for the warranty, you may need to contact support center for hardware check. I checked your profile and found one RN312 registered that still has warranty.
ProSupport for Business
