azureal
May 25, 2022Aspirant
ReadyNAS Ultra 2 Plus
Hello to the community. I wanted share an experience I have recently had with my first ReadyNAS which I purchased diskless from Amazon on October 11th, 2011. The Ultra 2 Plus (RNDP200U) which I f...
May 25, 2022Guru - Experienced User
azureal wrote:
Once my mirror re-syncs, I am considering upgrading the ReadyNAS from OS4 to OS6. I am wondering if the instructions and binaries linked in this thread will still hold true for upgrading my Ultra 2 Plus?
Yes. The only difference is that I am now recommending upgrading the stock memory to 2 GB before you convert it. That upgrade is inexpensive, and easy to do.
azureal
StephenB wrote:Yes. The only difference is that I am now recommending upgrading the stock memory to 2 GB before you convert it. That upgrade is inexpensive, and easy to do.
I was planning to ask that exact question, thank you.
I have several different 2GB DDR3 memory parts, one is sure to work.
Does this primarily give the OS more room to operate?
Thank you again.
