azureal
May 25, 2022Aspirant
ReadyNAS Ultra 2 Plus
Hello to the community. I wanted share an experience I have recently had with my first ReadyNAS which I purchased diskless from Amazon on October 11th, 2011. The Ultra 2 Plus (RNDP200U) which I f...
azureal
StephenB wrote:Yes. The only difference is that I am now recommending upgrading the stock memory to 2 GB before you convert it. That upgrade is inexpensive, and easy to do.
I was planning to ask that exact question, thank you.
I have several different 2GB DDR3 memory parts, one is sure to work.
Does this primarily give the OS more room to operate?
Thank you again.
