Ron73
Nov 23, 2016Aspirant
ReadyNAS Ultra 2 won't boot after power failure
Hi, I bought a ReadyNAS Ultra 2 back in 2012. I have two 2TB Seagate disks in it. I was using one disk as a file server and the other disk is a backup of the first disk. It has worked fine until ...
- Nov 23, 2016
The safest option is to use Netgear's Data Recovery service. It is expensive - but that's true of all data recovery services.
Or you could start with per-incident general support, and see if they can get your NAS running again.
So try my.netgear.com.
Ron73 wrote:
I have googled a little bit and found that the disk needs to be MBR(?) in order to be able to assign a drive letter to it in Windows 10. And then I found some info (http://www.partition-tool.com/resource/GPT-disk-partition-manager/convert-gpt-disk-to-mbr-disk.htm) saying that a program called EaseUS Partition Manager can convert a GPT disk to MBR without data loss. Is this correct? Can I use the free trial of EaseUS Partition Manager to convert my disk to MBR without losing the data on it? And would I then be able to access the disk from Windows 10?The real problem is that the PC can't handle linux file systems. You could try r-linux for windows, and see if that can read it.
DON'T try to convert anything though, you will almost certainly do damage.
Ron73
Nov 27, 2016Aspirant
I was able to recover my files with r-linux. Thanks alot for your help! :)
FramerV
Nov 27, 2016NETGEAR Employee Retired
Hi
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
