jhojlbr
Feb 25, 2014Aspirant
ReadyNAS Ultra 2
Hello, sorry for my bad English! I bought a ReadyNAS Ultra2, which was running fine! But then I had to factory reset it, because I planned on using it another place. I logged in to the NAS and ...
Feb 25, 2014Guru - Experienced User
You have an ultra 2, which is not a duo at all.
Did you use the ultra/pro instructions in the boot menu? The NAS will not be reachable for a while during the reset process. How long are you waiting?
Another approach is to remove the disks, and delete the partitions on a PC. Then reinsert them and power up the NAS.
